Whole Home Energy Usage
For those out there that are using metering solutions, what kind of kw demand peaks are you seeing in your homes? The reason I ask is i was reading through the stock luup files and it seems vera’s integrated power metering json file currently shows a max value of 10000 for the watts variable, which seems low for bigger houses.
Mid 20KW range for me.
JOD.
I posted a simple TED5000 plugin here:
[url=http://forum.micasaverde.com/index.php?topic=5371.0]http://forum.micasaverde.com/index.php?topic=5371.0[/url]
It only does one MTU right now, but will trigger voltage or wattage goes above/below scenes and notifications.
