Attached is a picture of the valve that I use to turn on water to fill the pool.
Is there a zwave valve that I could install instead of turning the handle?
Thanks!!!
There are at least 2 Z-wave valves that might work for you. The Homeseer is nicer, but more expensive:
The less expensive Econet attaches to a ball valve (that you purchase and install separately). This seems to have mixed reviews. If you have a newer ball valve, it appears to work fine, but if you have older, stiffer valve that is harder to turn then it may not work. See the reviews on Amazon.
https://www.econetcontrols.com/product/econet-z-wave-water-shutoff-ebv105/
I have not personally used either of these, so take this with a grain of salt.
Thanks a ton!
I’ll research and try one of them.
