Hi guys. I have read through a lot of posts here, but wonder if someone could save me some trouble and let me know the best choice for a (US) thermostat.
I want to be able to read/set from my VeraLite, and also do manual override at the thermostat itself. Remote monitoring via one of the iOS or Android apps is important.
I talked to my local HVAC guy, and he recommends Nest, for which I see a plugin. But the Nest is fairly expensive and has function I don’t want (learning, for example).
The RCS TZ45 is also good. Just like the Trane with the added ability to use remote temp sensors (if that’s a feature you need). And at retail, it’s only a couple bucks more.
