As I mentioned before I had Veralite working just fine until the firmware update screwed up my controller. So I have the Edge now. I got everything working except the garage door. There was some Plug In I had to use but I don’t remember. I am using a regular Lamp/Appliance Zwave with a tilt switch mounted to my garage door. Would someone please let me know what Plug In will work for my set up? Thank you.
Just to clarify I mean a plug in on my computer in the Vera Program. Thanks in advance.
It’s quite simple … the plugin is called “Garage Door”
You need to provide it the device ID for the door sensor and a switch device to initiate motion.
Thank you
