Having difficulty using the Everspring ST812-2 Flood Sensor with the Vera Edge wrunning firmware version 1.7.5185 (7.31), UI 7.
Had several Everspring ST812s happily controlled by a Vera 3 for many years. When I upgraded to Vera Edge things fell apart. Could not test, clear, or set the tripped or latched conditions.
Tried unpairing, then had to add the ST812 back as a Generic Z-wave device. The parms and variable settings ( ST812 >> Advanced >> Variable ) on the Vera Edge are a small subset of the variables for the same device on the Vera 3. Many are the same including,
device_type: urn:schemas-micasaverde-com:device:FloodSensor:1
device_json: D_FloodSensor1.json
Should I give up and replace the Everspring ST812-2 Flood Sensor with the Fibaro Flood Sensor FGFS-101 Gen5 ?
