Are there any sources for these products. I am interested mostly in the TZ45 stat because I read on here that the Trane version of this stat does not have the remote sensor terminals enabled [url=http://www.rcstechnology.com/pages/products.html]http://www.rcstechnology.com/pages/products.html[/url]
The energy meters are nice as well.
TZ-45 Thermostat is not available yet what you might want to look at is the RCS TZ43 Thermostat which has the ability of supporting 2 Optional Remote Temperature Sensors
I have this thermostat, but I can’t find the remote temp sensors anywhere. Does anyone have a link to where I could get them?
You can also create your own. See this thread for the specs. And perhaps @robinnes will confirm that this worked.
[quote=“oTi@, post:4, topic:168775”]@dfad1469,
You can also create your own. See this thread for the specs. And perhaps @robinnes will confirm that this worked.[/quote]
Sorry… I forgot to update that thread :-[
The $4 thermistor I ordered worked perfectly even on the end of a 50’+ cat5 run.
