Where heal gone ?
Where is the heal gone ?
I installed new device and sugested procedure after doing that always was do a zwave network heald.
Bur repair tab is gone
Why ?
[quote=“basd82, post:1, topic:189402”]Where is the heal gone ?
Why ?[/quote]
Because SEARCH button was created.
But in-case you come up with to many of the threads already started on the same topic, here you go.
http://support.getvera.com/customer/portal/articles/2078473
and
http://forum.micasaverde.com/index.php/topic,33252.0.html
And if those are to much here is a quote from the VERA release a few month back when it went bye bye.
Starting with the 7.09 release the Z-Wave firmware on the VeraLite and Vera3 controllers was upgraded to a newer version provided by Sigma, version 3.67 (300 series). Following the change it was determined that several options from the Z-Wave Settings page were no longer required for either platform and were removed from the 7.10 release from all the controllers, including VeraEdge (which is already running a newer version of Z-Wave, version 3.83 [500 series]).
The options which were removed are:
▾ Use Z-Wave version 3.20 instead of 2.78
▾ Use Vera routing instead of Z-Wave
▾ Limit neighbors to Z-Wave discovery
A more important aspect that was changed in the 7.10 release was the removal of the old Heal/Repair process which was no longer required with the latest versions of the Z-Wave firmware.
Why ?[/quote]
Hi basd82
You can run a network heal on UI7 by setting up a scene with lua code. See: http://forum.micasaverde.com/index.php/topic,34413.msg276588.html#msg276588
Z
