The ip cameras do not use the Zwave frequency. They are either wifi or ethernet. Any ip cam that exposes the camera image should work with Vera. See if any of the models listed on the forum are available in your country.
[quote=“garrettwp, post:2, topic:177530”]The ip cameras do not use the Zwave frequency. They are either wifi or ethernet. Any ip cam that exposes the camera image should work with Vera. See if any of the models listed on the forum are available in your country.
Garrett[/quote]
ohh i see, i tought it should be paired with zwave or something
is there a thread with all the models? can’t find something, can you please give a link for the thread?
also, what other websites there is in europe beside zwaveeurope that sells zwave products?
[quote=“yaron86, post:3, topic:177530”][quote=“garrettwp, post:2, topic:177530”]The ip cameras do not use the Zwave frequency. They are either wifi or ethernet. Any ip cam that exposes the camera image should work with Vera. See if any of the models listed on the forum are available in your country.
Garrett[/quote]
also, what other websites there is in europe beside zwaveeurope that sells zwave products?[/quote]
