I’ve searched the threads but usually only the problematic results end up here. I currently have a Intermatic CA5000 scene controller which from what I have gathered and tested does not function with Vera. I am at the stage of replacing this controller (which does nothing right now) and wanted to get everyones feedback with their setup.
I’m considering the 4 button Vizia RF+ scene controller and would be open to any other positive suggestions on a working scene controller with Vera. I am using mostly GE switches and outlets and expect there is a delay from the Vizia RF+ line since Vera processes this then sends commands.
I have had great sucess using the Intermatic/Wayne Dalton HA07 and HA09 controllers. They do work with Vera, and Vera can program then controllers directly so that there is no lag when pressing a button on the controller.
Intermatic is no longer making these, but there are plenty of them still available, and at reduced prices. Wyane Dalton still makes them.
Actually, I was looking for wall mounted scene controllers. Sorry for the confusion. I am looking for a scene controller than takes the place of my current wall switch and allows me to control 2+ scenes.
I like the Leviton VRCS2-MRZ Vizia RF + 2-Button Scene Controller.
It will control 2 scenes for the On switch positions and 2 scenes for the Off switch positions.
[quote=“JOD, post:5, topic:167419”]I like the Leviton VRCS2-MRZ Vizia RF + 2-Button Scene Controller.
It will control 2 scenes for the On switch positions and 2 scenes for the Off switch positions.[/quote]
JOD,
That sounds exactly like what I want. Is this scene controller setup through Vera? In other words I include it into my network and I can adjust the scenes through Vera? If the on and off of 2 scenes were working I would be very happy!
You add it as a scene controller first, then add each switch so you end up with 3 devices within vera.
Create a new scene or pick an existing one, go to the scene controller portion within Vera and goto scenes.
There you can assign a scene to each button & each on & each off for a total of 4 scenes.
The two other devices within Vera control the local loads attached to the actual switches.
JOD.
