I am trying to log on without the wire and to get into the device you have to logon to its wifi first. I have no idea what the password is.
I think it is located on a sticker on the bottom of your ezlo plus. It it listed as WIFI:
Should be below the MAC address and above the SSID.
Hi Scott,
I wrote back to you via the Zendesk ticket we have open telling you how to connect your Ezlo Plus to your WiFi network, and it does not require connecting to the unit’s WiFi network. I also included a short video telling you how to navigate to the required menu. If you experience issues connecting the controller via WiFi because it tells you it cannot connect to your WiFi network, please make sure you have granted the Vera mobile app all the permissions it requires to work correctly, and make sure to reply to the Zendesk ticket.
Thanks!
