The only thing I use it for is a scavenger hunt through the UI to remember where to turn it off.
If you’ve got wifi already, use that for anything bandwidth heavy.
It might be possible to link other wifi-linked HA stuff to it and use it as an access point, so they’d be directly linked to the controller rather than having a router middleman.
Other than that, I’m not sure I’d use it for anything.
For devices that only do short range enrolling, I put the vera on a small ups, turn on wifi, and control the enrollment process from my phone linked to the vera.
The other “maybe” use, was if you have a place with no internet and you have a wifi thermostat or something. But in general, I have a dedicated router for my HA, with my LAN on another (firewall facing the HA).
Ditto, like kigmatzomat I just discovered Vera can run on Wifi so rather than dragging an ethernet cable all over the house to enroll devices, I run it on Wifi. Aside from that, I have no use for it (no IP cameras presently, although that will probably change in the future).
-MC
