Right. Thanks for the answer. Would eventually like to add a camera or two down and sensors down the road. This setup should be able to handle this correct?
you may face a range problem if the 3 devices will be installed relatively far from each other, especially the lock and Vera. If that’s the case you may need intermediary z-wave node(s) in between to allow mesh routing and improve range.
That shouldn’t be a problem. The Vera will be installed in the living room, only about 10 feet from the front door. The thermostat is about 15 feet from the living room so they’re all pretty close.
