Hi
I’ve had the same devices set up in the garage for over 2 years now. I very seldom use my vera to remote control anything, as I use its automation to do everything and it runs pretty well.
However, I logged in the other day and there are dozens of “_sensor” devices (see attachment). Any way to tell what they are connected to? I have several on/off zwave devices (switches, etc), two sensors, and then a ‘power meter’ that connects to the breaker box. I’ve never used it, so if that’s what’s creating all these things, I will gladly remove it. Any way to remove these things in bulk?
Also noticed I’m running 1.6.641, and they are recommending 1.7.730. Any problems with updates? I generally don’t update anything unless there’s a problem, but I like having the two ‘GUIs’ - the ‘advanced mode’ and ‘simple mode’.
