But vera only runs the first scene and ignores the second one, anyone knows why? , because it is at the same time? or something wrong with the code? When I flip the 2 scenes in that code , the other one is run.
IN short; only the first scene runs , the second one does nothing
go to “command prompt” and run the batch file manually, and check whether both wget commands run or not, and whether any error messages are displayed or not
@ Capjay, Thanks … It turns out that both scenes got the command , but the activation didn’t work somehow . Not sure if it is because the request is to activate them at the same time. Sounds wierd, I think you can activate scenes together…
Anyway , I inserted a delay code in between , from 20 seconds it works fine , below that … the second scene is not activated… very wierd…
