Hi Mark,
Minor issue but for some reason in my top left-hand weather/temperature pane I have two instances of outdoor weather temperature/humidity readings. The correct one, it titled “Outdoor” which is displaying the accurate readings from the Vera Wunderground weather plugin. However, there is another set of data titled “Outdoors” which displays a similar temperature/humidity reading, but it’s always off. I have no idea where this second instance of outdoor weather data comes from (its not the high/low temp reading from underground) and I’d prefer it to be deleted if possible. Any ideas?
Also, I know HVAC has it’s own separate pane but it’d be cool if my tstat’s current temp/humidity reading could be added to the top left weather data pane in a future update. If I wasn’t looking to change the tstat’s set-point it’d be nice to see it at a glance in that top left pane along with my two Everspring ST814 sensors and my underground outdoor temp/humidity reading. Is that a possibility at all?
Just wanna give you a ton of kudos while I’m at it: SimpleWave has the sleekest and prettiest user interface I’ve ever seen for a Z-Wave control app, and your responsiveness to questions on comments on this forum about the app is awesome. Keep it up!
