Is energy monitoring for washer/dryer’s the best way to track usage and notification when a cycle is complete? Are there any other sensors?
Also, while my washer is 120V <15A, my dryer runs at 220V and I do not believe I have found any plug style adapters that work at that voltage (only hardwired devices).
What are folks doing with 220V electric dryers?
I’ve seen some mention of using vibration sensors, but have not located a z-wave one that looks like it would work. Most I’ve seen are made to detect glass breaking.
Why not just remove plug and add hardware device to washer cable and then put a plug on it… You will find dual voltage in many countries that use 110v as they use a 3 wire system, 2 phase and one neutral. 220v betwen phases and 110v between phase and neutral.
That’s a typical laundry room in a US (and Canada?) house these days. Dedicated 120V/15A for washer, 220V/30A for dryer. Sometimes a natural gas hookup for dryer as well, in which case the appliance will usually use 120V instead of 220V just for its controls.
For the Dryer I used a couple of Furnace pressure switches 1 for cycle end (no psi) & 1 for plugged Vent ( Hi psi). For the Washer, I ended up using a micro switch on the lid lock. Lid unlocks at end of a cycle or when other stuff needs to be added. All of this is wired into 3 Linear door switches. I then announce the end of cycles on wall mounted tables thru out the House & Garage. Wife thought it was petty stupid, but now if it’s not working I really hear
I tried going the wattage route but found that my washer never went to zero & wattage in the cycles process varied a lot. On the Dryer I wanted to pick up the Dryer vent plug notification any way.
I saw that previously and don’t want to spend more than the value of the dryer on it Maybe I’ll just rig up a sound sensor or something for my wife to listen for.
Think the Aeotec energy meter would be easiest, Home Energy Meter – Aeotec,
You can figure out what the energy profile looks like when it is off and alert on that. Assume you have a separate breaker for the dryer circuit.
