Hello All.
I recently bought a couple MCV to automate my vacation homes. In the future, I also plan on automating other peoples homes and I am learning all that I can. ![]()
I will start off with a little butt kissing: MCV tech support is WONDERFUL! I have called them 5 or 6 times. A bad hold time was 1 minute! :-*
Re: locks. For security reasons, I love that I can let people in and out without giving them keys. The MCV notification feature is powerful because when the cleaner enters our home, I know when she started. Or if a service tech arrived to do some work, I can call his cell to ask him questions while he is at the job. After reading peoples posts about the motorized lock (which I love by the way), I picked the Kwikset version over the Schlage.
Now to the security problem. Iāve learned that once someone enters in a MANUAL passcode on the Kwikset (by hitting the black button to program) it cannot be changed or viewed by MVC or any other system. Letās say that someone is in your home and hits the black button once and punches in the code 13579. 13579 will let them in your home just like having a key. You cannot remove that code electronically. That is because 13579 is now code1 and now there will always be a code1. Tech support said you cannot push buttons to take code1out. What I ended up doing is resetting the lock to factory default (which meant I needed to relearn that lock on MCV). You can override user 1 for instance with another code1 but like I said, there will also be a user1 code in the system.
I called Dennis at Kwikset and he talked later talked with engineering. To my amazement he said no one has every asked them about this. I explained that Iāve had non-Zwave keypads from Schlage in the past and they require someone to enter in a master code to add or subtract anything. IMHO, that is the only way a lock should be designed.
His point was once someone enters your home, that means they would be allowed to change the code (or else why let them in your home). ??? I explained to him that is like saying that you would allow anyone who enters your home the ability to make a copy of your front door key! He disagreed. I explained that the reason for a lock is for āsecurityā. Therefore folks like Schlage (who require pass-codes) understand that security doesnāt mean that just because people are in your home you want to give them an (electronic) key!
Has anyone else thought about this?? Does the new Yale work like the Schlage??
