Anyone get this camera to work with UI5? I received the camera yesterday, and it works well with the supplied software. I was able to set up the IP, wireless network, password etc. MIOS din’t see the camera, but I was able to manually add it. However it doesn’t get the video. I would appreciate any help if someone has the required device parameters and files.
Wow, so no one out there can help get this camera set up? It easily gets recognized by iPhone/Google apps to view and control this camera. I just need help getting it set up for use with Vera. ![]()
I was able to see it , but no pan/tilt.
to get to work you have to make sure that on the camera’s ip is not static and keep the port on 80. also on the mcv camera setup on the url space put: videostream.cgi
but I sitll need to make the pan/tilt work. I downloaded the I-Panasonic.xml and edit it… but no luck.
Hello, Mr Javijuan,
Good day.
This is Royan from Wanscam, which is a manufacturer of IP Camera.
I’d like to give you a hand, would you please download our app e-view 7 to see if it can be controlled by this app?
If it can’t, you can contact our support on Skype: wanscam006, or I will also be pleased to help, my e-mail address: sales6@wanscam.com, Skype ID: wanscam006.
Best Regards,
Royan
