WallC-S2 - anyone else having problems getting it to trigger Vera?
I’m trying to figure out how come my WallC switches/wall controllers don’t seem to fire my scenes in any predictable way. They fire some times, but most of the times they don’t.
Anyone else having similar problems?
Hi Tiwas,
I have one of these devices, and currently none of my scenes trigger. I’m currently trying the following:
http://forum.micasaverde.com/index.php?topic=32245.0
Can I ask how you’ve set up this switch?
Tony
[quote=“tony-park, post:2, topic:192005”]Hi Tiwas,
Tony[/quote]
I got rid of mine. Too battery hungry and unriliable, but…once you include it you should be able to run a scene and run luup like this:
[code]luup.call_delay(‘scene_controller’, 1)
function scene_controller()
local lastSceneID = luup.variable_get("urn:micasaverde-com:serviceId:SceneController1", "LastSceneID", 422)
luup.log("!DEBUG! Scene: "WallC soverom". lastSceneID: " … lastSceneID)
if (lastSceneID == "11") then luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum = "30"}, 0) -- All on (day)
elseif(lastSceneID == "21") then luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum = "62"}, 0) -- All off
elseif(lastSceneID == "31") then luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum = "44"}, 0) -- God natt fase 1
elseif(lastSceneID == "41") then luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum = "45"}, 0) -- God natt fase 1
elseif(lastSceneID == "42") then luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum = "62"}, 0)
end[/code]
I guess 422 was my id for the wallc, but I cannot quite remember what I did. You should be able to get it to trigger the scene when a button is pushed and then change the “SceneNum” to whatever scene id you want to run.
Good luck!
