Does anyone know if there is a wall receptacle/outlet that also reports energy usage? The closest thing I have found are the Aeon Labs Smart Switch and Mi Casa Verde SmartSwitch.
Thanks for the help.
There aren’t any that I’m aware of.
Do you expect that the power usage of the things plugged into the outlet will change routinely over time? If not, you can manually add wattage figures under device properties. I do this for most of my devices.
Maybe this one: The third line says “energy measurement via controller”.
Cor
Thanks for the feedback. I am going to use them for outlets where electrical components are uses so I expect the power usage to change as they are being used and not being used. I will probably go with the SmartSwitch for now since I am pretty sure it will give me what I am looking for. I was just trying to avoid that added “bulk” of them dangling from the wall.
[quote=“Cor, post:3, topic:175275”]Maybe this one: The third line says “energy measurement via controller”.
Cor[/quote]
Sorry ,just noticed I forgot to insert the link:
[url=http://www.ezhome.nl/zwave/fibaro-wall-plug.html]http://www.ezhome.nl/zwave/fibaro-wall-plug.html[/url]
