Wall dimmer switch for controlling Somfy ST-50
Hi all, I’m about to make a purchase of some cellular blinds from www.shadesshuttersblinds.com, equipped with Somfy ST-50 motors. For Z-Wave control I will install Z-Wave to ILT interface. So far so good. But what I’d ideally like is a dimmer switch that can also control the blind in that one room, not just from a scene controller.
I’ve been searching and can’t see an easy way to do this. Is there a way to pair a dimmer switch with an ILT interface so that the 0-100% settings are matched? I think that could be done using a group association, but does a dimmer switch even work without load? Has anyone got a similar set up of wired wall dimmer-type operating a Z-ILT Interface enabled blind?
