What is your version number ( check inside J_ALTUI_uimgr.js file and inside L_ALTUI.lua file) to report both version numbers?
[code]Browser footer:
AltUI v2.18.2331
J_ALTUI_uimgr.js:
var ALTUI_revision = “$Revision: 2331 $”;
L_ALTUI.lua:
local version = “v2.18”
local SWVERSION = “3.3.1” – “2.2.4”
[/code]
Using the above AltUI versions on a Vera 3 and using Firefox.
With the ‘:3480’ style URL everything works, except the icons stored on Vera are not accessible.
-- using this URL
http://<my_ip_address>:3480/data_request?id=lr_ALTUI_Handler&command=home
-- AltUI trys to source the icons with this style of URL:
-- Putting the same URL into the Firefox browser returns "Connection reset"
http://<my_ip_address>:3480/cmh/skins/default/img/devices/device_states/window_covering_80.png
With the ‘port_3480’ style URL “Waiting Initial Data” is shown but the icons stored on Vera can now be retrieved successfully.
-- using this URL
http://<my_ip_address>/port_3480/data_request?id=lr_ALTUI_Handler&command=home
-- AltUI sources the icons with this style of URL:
-- Putting the same URL into the Firefox browser returns the icon OK
http://<my_ip_address>/cmh/skins/default/img/devices/device_states/window_covering_80.png
However the console sometimes shows this:
2018-04-15T01:34:42.530Z: ALTUI v2.18:_getFileContent( D_ZWaveNetwork.xml ) ==> asking content to Vera J_ALTUI_utils.js:2238:4
TypeError: scene is null[Learn More] Line number: J_ALTUI_uimgr.js:14872:15
The console mostly shows this:
[code]Line number: jquery.min.js:2:30920
jQuery.Deferred exception: scene is null updateFavoriteScene/map<@http://<my_ip_address>/port_3480/J_ALTUI_uimgr.js:14872:15
map@http://ajax.googleapis.com/ajax/libs/jquery/3.3.1/jquery.min.js:2:3218
updateFavoriteScene@http://<my_ip_address>/port_3480/J_ALTUI_uimgr.js:14869:15
signal@http://<my_ip_address>/port_3480/J_ALTUI_uimgr.js:14391:5
_publishEvent/<@J_ALTUI_utils.js:2461:7
each@http://ajax.googleapis.com/ajax/libs/jquery/3.3.1/jquery.min.js:2:2571
_publishEvent@J_ALTUI_utils.js:2459:4
_onInitLocalization2/</<@http://<my_ip_address>/port_3480/J_ALTUI_uimgr.js:14571:5
l@http://ajax.googleapis.com/ajax/libs/jquery/3.3.1/jquery.min.js:2:29373
a/</c<@http://ajax.googleapis.com/ajax/libs/jquery/3.3.1/jquery.min.js:2:29677
undefined
[/code]
Note that I have one only “Favorite scene”.
Note that in Chrome everything works OK
Now on openLuup: this URL all works OK and the local icons all show:
http://<my_ip_address>:3480/data_request?id=lr_ALTUI_Handler&command=home#
With this URL you get unable to connect:
http://<my_ip_address>/port_3480/data_request?id=lr_ALTUI_Handler&command=home#
With openLuup I guess it doesn’t have a /port_3480/ redirect and that :3480 is always used.
With Vera - I’m unsure what is meant to be used these days: /port_3480/ or :3480. I suspect the former.
