@Waynehead99 I think the current VoxCommando plugin aren’t setting/querying the TemperatureSetpoint1_Cool or TemperatureSetpoint1_Heat…so you would need to do this with the VoXCommando Vera.Raw command and write your own logic…or perhaps this support will be added in the future like getting the thermostat temperature (not cool or heat set point).
From Rex’s Sample Code, here are the key items:
http://forum.micasaverde.com/index.php/topic,18679.msg152234.html#msg152234
Thermostat
Set ModeTarget, read ModeStatus. “Off”, “HeatOn”, “CoolOn”, “AutoChangeOver”.
Code: [Select]
local mode = luup.variable_get(“urn:upnp-org:serviceId:HVAC_UserOperatingMode1”, “ModeStatus”, dID)
luup.call_action(“urn:upnp-org:serviceId:HVAC_UserOperatingMode1”, “SetModeTarget”, {NewModeTarget = “Off”}, dID)
Set and read CurrentSetpoint. (Degrees)
Code: [Select]
local setpoint = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”, “CurrentSetpoint”, dID)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”, “SetCurrentSetpoint”, {NewCurrentSetpoint = “25”}, dID)
local setpoint = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”, “CurrentSetpoint”, dID)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”, “SetCurrentSetpoint”, {NewCurrentSetpoint = “30”}, dID)
