Hi. I’m a new Vera user. I just set up the the Vera Home Control Starter Solution (the one with the VeraLite G, lamp module, and VistaCam SD). The camera seems to be working fine over wifi, but it keeps going offline for exactly 5 minutes at a time, almost to the second. It does this multiple times a day. If it wasn’t such a specific amount of time I would have figured it was just a weak signal (which it shouldn’t be anyway as it’s only about 20 feet from my router and VeraLite G. I have other wifi devices farther away with no problems). Any thoughts on what could be causing this or how to fix it? Thanks!
Is that the PT? Having issues with mine. Does sound like a wifi issue that you have. When Lua starts up are you seeing any errors?
I see same msgs in ui7
on of my cameras and my vera are hard wired, not wireless and still see issue there as well
not really issue per say, as the camera’s still work fine it seems when I view then in vera
I have both a PT (LAN CABLE) and a SD (WIRELESS)
It’s a VistaCam SD. And yes I’m also on UI7. Glad to hear I’m not the only one with this issue. Hmm.
