VistaCam HD no pan and tilt.....ready to give up
Ok…I have read every forum entry on the topic and have tried several remedies. I have reset the VeraLite four times and deleted and reinstalled the camera device a dozen times. I get to the same place every time. I see an image through the portal but I cannot control the camera in any way. The camera is connected via ethernet for now (i want wireless but not ready to move on until i understand the movement issue).
There are two things that might be contributing…but i’m not sure:
  1. Do i need to do anything around ports?
  2. Could I be on the wrong firmware/Ui version? I don’t know, because I can’t tell what UI version i’m on…my firmware is 1.6.641. I tried to go back a version a few times but none of the links I found could find my device to roll it back
[quote=“gmcole92, post:1, topic:179180”]Ok…I have read every forum entry on the topic and have tried several remedies. I have reset the VeraLite four times and deleted and reinstalled the camera device a dozen times. I get to the same place every time. I see an image through the portal but I cannot control the camera in any way. The camera is connected via ethernet for now (i want wireless but not ready to move on until i understand the movement issue).
  2. Could I be on the wrong firmware/Ui version? I don’t know, because I can’t tell what UI version i’m on…my firmware is 1.6.641. I tried to go back a version a few times but none of the links I found could find my device to roll it back[/quote]
Hi–
You’re breaking new ground here… Don’t know that any of us has much experience on UI6. Can you please identify specifically what camera you’re using? Also, how did you get to 1.6.641 on VeraLite?
Don
If you after downgrading firmware see:
http://forum.micasaverde.com/index.php/topic,22637.msg152946.html#msg152946
When I installed the Veralite for the first time, there was a button that said new firmware available. Being the naive Vera-virgin I am, I clicked on it.
I’m using the VistaCam HD that I purchased with the VeraLite through getvera.com.
I am going through the same drama. Just got a Foscam FI9821W V2 and having the usual Vera “challenges” getting it going.
Its too bad everything needs such effort to get going on Vera, it will never escape enthusiast usage and enter mainstream without better tools and crisper plug ins and instructions/documentation.
Anyway enough rant. I got the camera mostly working by doing the following. I am running a Vera lite with 1.5.622 software.
  1. Set my router so the camera has a “reservation DHCP” address. Similar to static IP but easier to do for me.
  2. Get the camera working with it’s built in browser interface at the IP address of the camera before trying anything with Vera. Started with Ethernet then got it switched over to WiFi. Then went on to change user name to my own choice and added a robust password. While in there change Pan & Tilt Speed to Very slow, more on this later. Also go ahead and set a couple of presets on the live video tab as well. I also changed the /Network/Port/HTTP Port from the factory default 83 to 80.
  3. Make sure you have the camera working via its browser before trying to add to Vera.
  4. Ready to include into Vera. Added the camera in the devices tab as a manual install. Search for its IP address in the secondary page to select it. You should know the IP address due to step 2. Installed it as a Foscam camera. Did not get a screen shot from the camera but said OK and installed in anyway!
  5. Once device created went into advanced tab and replaced URL section with this:
http://192.xxx.x.xxx/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=“YourLoginName”&pwd=“YourPassword”
Where 192.xxx.xxx.xxx is the IP address for your camera and you enter in your actual login name and password without the quotes later in the string.
6) This should give you an image but pan and tilt won’t work. The default Foscam plugin doesn’t work for this camera (although it works fine for my Foscam SD PT cameras).
7) Go get this file I_Foscam98HD from here http://forum.micasaverde.com/index.php/topic,11027.msg101679.html#msg101679
8eight) Upload it into your Vera via the APPS/Develop Apps/Luup Files page. Use the Upload files to the right to find the file on your PC and then upload it.
9) Go back to the device advanced tab and change the impl_file line to I_Foscam98HD. This should get PT working. I found the Panning very jumpy so I set the StepSize to .1 in the advanced tab but not sure it recognizes <1 entries. I also changed camera to very slow Pan (this is why I asked you to do it in step 2 above). You should be able to Pan and Tilt and the presets you entered before should work (at setting #5 and beyond, Foscam has reserved the first 4 presets to (useless) factory defined ones).
So this got me basic HD images working with Vera on my browser and iPhone/iPad clients. PT both works and I’ve started playing with the presets. I hate that the 1st four presets are wasted on factory test settings but I haven’t figured out yet how to delete these in the camera or get the plug in to start at preset #5 for its first setting. I imagine I could hack the impl file to skip the first 4 but haven’t gotten that far yet. I am still a nubee on Luup scripting and coding is not my profession.
I’m sure there are other ways to get this done and maybe a couple steps could be simplified but this worked for me. Anyway hopefully this saves some folks the trial and error that seems standard fare for Vera?
Cheers
Update:
Was able to delete the factory presets. To do this you must delete the cruise maps first and any start up position that uses a preset. Once all usage of presets are gone you can delete the presets. There is a catch though. You can’t do it over the GUI. You need to do it via CGI commands. I used a browser and edited the address line as needed then hit return to effect the command. I guess more sophisticated types could write a short script to do this.
The CGI syntax (and manual for that matter) can be found here: http://foscam.us/forum/cgi-sdk-for-hd-camera-t6045.html#p28979
