I’m working on setting up the panel (V20p) on a bench and I came across a configuration option in *56. I’m using an EVL-4 but the question is in regards to Report Code of ‘10’ whereby it allows a call out to the Central Station Monitoring Service. Do I disable this option (00 00) or simply leave it at default (01 00)? I figured I’d ask the experts here as this is my first panel setup for 24 zones.
Much appreciated…
