Hi, I recently installed this plugin and hooked up my Vera3 to my Powermax Complete panel via a RS-232/USB connection. The Partition and Panel devices were created automatically in the Vera web interface but none of the sensor devices were created. Any idea why these devices weren’t created automatically ? The panel is already fully programmed so I don’t want to create device manually. Thanks.
Hi…
Have you looked here:
http://code.mios.com/trac/mios_visonic-powermax
It should give you what your looking for… I use the Ademco panel… so I can’t speak to this personally.
Does the plugin show Standard or Powerlink mode? The devices are only created automatically in Powerlink mode, but you’ll have to follow the enrollment procedure.
It was in Powerlink mode but now it’s showing a LUA start-up failure error (it was running ok when I first posted this question)
Please make sure plugin debug is on and capture the logs. Please send the log files (LuaUPnP.log and powermax_settings.txt) to vera.powermax at gmail.com.
Thanks for your awesome support - The new LUA file you provided completely fixed the issue.
@mdcv: thanks for the info & letting me know it now works OK. I’ll roll that change into a next release.
