no, device is not broken ;).
I didn’t want to say that it doesn’t work… It will give acoustic alarm and strobe - and you can disable it.
But you can not setup strobe alarm only and can not define the alarm time.
The device is missing in the productcs library - this is the problem, that’s why he right confg file can not be taken.
I think I have found a solution - will make some tests and publish it later.
I just tried to connect my Vision Siren (ZM1601) to Vera Lite and it seems that my Vera does not recognise the device. I have upgraded my Vera Lite to Firmware version 1.5.672 could this cause the issue.
Process:
1 remove bracket
2 inserted batteries
3 set my vera lite to Add new devices
4 On the alarm pushed the program button
Process:
1 remove bracket
What am I doing wrong?
All help is welcome
Ron[/quote]
It works on my VeraLite with the same FW.
It does however turn up as a “switch”, for ie. light bulbs, but it works (audio and visual) by pressing On/Off, which also makes it work just fine for anything I can think of.
Ok, if anyone else is stuck with this, to get it to work, edit the device (if its shown up as a binary switch)
Go to “Advanced” tab
under device_file put in “D_Siren1.xml”
save then reload
go back to the the device popup, under “Device Options” click “Add configuration settings” add
variable, data size, desired value
0, 1 byte dec, 0
1, 1 byte dec, 3
the first desired value can be 0 for siren and strobe, 1 for siren only, 2 for strobe only
the second desired value can be 0 for 30 seconds, 1 for 60 seconds, 2 for 120 seconds, 3 for dont stop.
So in the above settings I have strobe and siren and set to dont stop.
I have no idea why the default is 30 seconds only, which is completely stupid for an alarm siren…
