I’m looking for a virtual switch which turns off automatically after pushing. It should be used as a trigger for PLEG. I found VirtualSwitch under miosApps but it doesn’t support this?
How can I do this without making a scene that turns it off?
I want to use it in HomeWave so it should be compatible. Otherwise I would use Multiswitch.
Thanks, I will probably make one scene with all my virtual momentary switches and set them all to off if any one of them triggers. That way I only have to do it once.
The idea is to use this to initialize home cinema but also for setting the volume to a specific level.
