Virtual HTTP Devices Plug-in v2
I just released v2 of my Virtual HTTP Devices Plug-in. As always, 100% local, 100% standard, mobile friendly and working on openluup/altui as well.
What’s new in v2:
  • Master/Children: now you can just create a master and have any number of children attached. They will still work separately, but this will greatly improve memory consumption on Vera. Please see GitHub for guidance on migration. No need to do it unless you have many devices on your system.
  • async update of device’s status. If you want to update the status of a device separately, just return something different than the HTTP code 200/300 family. it’s useful if your device doesn’t complete the response with the call and you want to update its status. Just use a normal Vera call to update the corresponding variable
  • added support for Scene Controllers (see my post in Shelly i3 for a use case)
  • more work around switches/heaters
  • stabilization and fixes
I’m still not sure I will add it to the official store, so get it from GitHub.
Hello @therealdb,
there is a bug in the dimmable light, the brightness url is missing
@therealdb Well done superb plugin :wink:
yep, thanks for noticing. fixed in the new version published on GitHub.
Hi @therealdb
Hope all is well, I’m trying to figure out how best I can make a 4 plug IP switch work with your http plugin, any guidance would be appreciated.. The details below hopefully will help.
  1. on / off commands for one socket are sent via the following command.
http://192.168.1.199/set.cmd?user=admin+pass=12345678+cmd=setpower+p61=1
http://192.168.1.199/set.cmd?user=admin+pass=12345678+cmd=setpower+p61=0
  1. on/off commands for multiple sockets sent at the same time is as follows
http://192.168.1.199:80/set.cmd?user=admin+pass=12345678+cmd=setpower+p61=1+p62=0+p63=1+p64=0
  1. the status of all sockets can be requested like this.
http://192.168.1.199/set.cmd?user=admin+pass=12345678+cmd=getpower
Which returns this.
p61=1,p62=0,p63=0,p64=0
HTTP/1.0 200 OK
Connection: close
The last one, (FYI) I’ve got a bit of Lua code to capture the specific socket values.
local http = require "socket.http"
local result, status = http.request("http://192.168.1.199:80/set.cmd?user=admin+pass=12345678+cmd=getpower")
local report = string.match(result, 'p61=%d.p62=%d.p63=%d.p64=%d')
local pw1, pw2, pw3, pw4 = string.match(report, "(p%d+=%d),(p%d+=%d),(p%d+=%d),(p%d+=%d)")
print(string.sub(pw1, -1))
print(string.sub(pw2, -1))
print(string.sub(pw3, -1))
print(string.sub(pw4, -1))
I have the plugin installed and added the on and off commands, but they don’t seem to work. (See below)
@therealdb
Another question I wanted to ask was around future support for command line requests? For example I make a few calls to other devices, e.g. my NAS to see if a VM is running on a host. E.g below.
local command = io.popen("ssh -y -i /etc/dropbear/dropbear_rsa_host_key pi@192.168.1.37 '/QVS/usr/bin/virsh list --all' 2>&1")
print(command)
local msg = command:read("*a")
print(msg)
Which returns this.
Id    Name                           State
 5     6e856cb2-2793-4acd-9a15-9e1d28ff0caf running
 -     137f2fcf-2db2-43a8-8dc3-9964dfe6aabf shut off
 -     4ad65c4d-99d5-4c2f-aca4-edaca820e8df shut off
 -     7b0f8c69-de6y-4aa2-a601-1414304fff30 shut off
 -     84e9b437-7e09-4ee6-ba4e-201096b9266c shut off
 -     d7216338-8e39-4107-b8e0-2019cd150ed2 shut off
  1. set debugmode variable to 1 and look at logs. There’s maybe something going on.
  2. you could send any complex command via curl support. Look at docs.
If you want to sync back status, you’ll have to write some code. I was thinking of a way to ping an endpoint for status, but I’m not sure it could be an easy task to be general enough.
Hi @therealdb
Just wanted to suggest a possible idea for a future feature and that’s to add a ‘GetStatusURL’ option, where the person can add a url in to get the current status and your plugin will looks for either a “1” or “True” for on, and a “0” or “false” for off being returned.
If their ‘GetStatusURL’ does not return exactly that, then also have a ‘GetStatusLua’ option too, where you can put some Lua code in that the plugin runs to return once again either a “1” or “True” for on, and a “0” or “false” for off.
I appreciate you can do scene for this , and set variables, but I just thought it would be nice to have everything in the same device/plugin etc.
I can’t create an RGBW dimmer. Please check my parameters screenshot
name
device_type
urn:schemas-upnp-org:device:DimmableRGBLight:1
altid
ip
mac
manufacturer
model
id_parent
0
nobulk
embedded
disabled
restricted
device_file
D_VirtualRGBW1.xml
id
56
room
0
time_created
1614605503
plugin
9281
impl_file
I_VirtualRGBW1.xml
category_num
4
subcategory_num
2
device_json
D_VirtualRGBW1.json
local_udn
uuid:4d494342-5342-5645-0038-000002b06c71
Parameters are OK. go to variables, set debugmode to 1 and look at logs. You’ll find better instructions on the readme.
I’m still not 100% convinced. The use case here is to avoid polling and using pushing instead (ie from Tasmota or whatever), but I’ll try to add something in the next version.
Thanks @therealdb
Perhaps I’m missing something, how do you get push to work with quite old and very basic http request based plug sockets (those that just have basic on/off/status capability ) ?
You can’t and your use case obviously needs polling and this feature.
Yep afraid so, all my http sockets and some of my lights only work like that … (I must be oldskool) :slight_smile:
I’m trying to stay away from polling, because I’m sure it will impact the stability of your Vera. But I’ll add it anyway, as an optional feature for everyone who needs it and want to run it at their own risk.
Thanks, so much :slight_smile:
How will you look to set up the polling feature?
Will it be something where I set a frequency variable (e.g number of seconds) between polls so I know it will always be accurate after a period time ?
Or would you look to trigger that in a different way maybe x seconds after any command is sent ?
Or ideally both?
Just polling, with a configured variable. Otherwise it will become too complex to handle.
Hi @therealdb
Hope all is well with you.
I’m trying to turn off a registered http devices in Vera UI, which I know is already turned off at source. So I’m not expecting the command to work, I’m just looking to make the UI match with the actual state of the device,
As I can’t seem to turn it off in the UI, looking in the log, there seems to be this related entries .
01	09/03/21 20:20:45.391	luup_require can't find http_async <0x6f246520>
Is there a way to update the device status in the UI even if the source device is unresponsive ( because it’s off)?
Yes, just update the status variable. It should be covered in the readme. I’m using it to initiate a request from the Ui and update the status based on the actual action being execute successfully.
@therealdb Can you modify the Virtual Heater so it can be used as a HVAC thermostat? The idea is to be able to change mode and setpoint it does not need to turn off when Cool/Heat temperature is archived i need it to control third party HVAC Split system through HTTP calls.
