Virtual Devices from MCV
I am having trouble getting the Virtual Thermostat to work posted by mcvflorin [url=http://forum.micasaverde.com/index.php/topic,8363.msg53275.html#msg53275]http://forum.micasaverde.com/index.php/topic,8363.msg53275.html#msg53275[/url]
I have no implementation errors on the fan control…does anyone else have a working model or know what is missing?
The UI shows a “No Implementation Error”
Tim
Tim, Ever get an answer? I have the same issue.
Yes I did!
Re: (No subject) « Sent to: TimAlls on: March 05, 2012, 07:10:11 am » Hi Tim, I haven't implemented this action for the Virtual Thermostat, though it would be easy to do. Unfortunately I don't have time today, so I'll implement it tomorrow morning.
That was from MCVflorin but I haven't seen a working version yet!
As soon as it is working I have a plugin that allow the Vera to be used as a Thermostat using a Temperature Sensor and a Relay!
Regards
Tim Alls
AllSeas Yachts
Do you know what variables in the stat we can ask for to determine that heat, cool, or fan is actually ON.
I will have to look at the XML file…can’t remember off the top of my head.
I wil check it out after work tonight!
Regards
Tim
Sorry, missed a line in my last post.
I think it is urn:micasaverde.com:serviceId:HVAC_OperatingState1
The question is where do we find out what all the possible values are? Is there such a doc?
IF I remember correctly all of them are listed in the XML file.
I will check when I have a chance…I don’t think its in the Ever Spanning Wiki which has the answer to all of lifes questions in it…IF you can find them!
Regards
Tim
[quote=“TimAlls, post:3, topic:170745”]Yes I did!
Regards
Tim Alls
AllSeas Yachts[/quote]
Sounds like an interesting plugin. Are you looking at setting one relay to call for heat and another for cooling.
John
The plugin I have is just for cooling at the moment…that is all I needed. It would be easy to modify it for heat or both. I was planning on using it as a manual over ride for a normal thermostat so that even if Vera was bricked that it wouldn’t hurt anything.
Regards
Tim Alls
AllSeas Yachts
