Virtual Clock Help
Is there any tutorial on how to use the virtual clock app? I am looking for a simple switch to turn a light on at a certain time. and then back off at a different time.
Is there a reason you want to use this plugin? You can achieve what you mentioned by creating a new Scene and then entering info in the “Schedule” tab.
Agree with @Kenray536, if it’s a simple turn a switch on and/or off at a certain time then creating a simple Scene will accomplish what you need. If you are looking to get more complex or creative e.g. to turn on only at Night, or turn on when a sensor is tripped then recommend using PLEG. Mike
Thank you - I was making this harder than it needed to be ??? ???
Just to close out… The instructions (translated) can be found at https://translate.googleusercontent.com/translate_c?depth=1&nv=1&rurl=translate.google.com&sl=auto&tl=en&u=https://sbdomotique.wordpress.com/2012/07/12/vclock-beta/&usg=ALkJrhgKfpaKfxrMdC6DZkTlqmhlv0r9ow
