Video camera basics?
Hi all,
I’m trying to figure out what route to go for our video cameras (2 indoor, 3 outdoor). We’ve wired for a POE camera but I’ve learned that we can get power through that with some sort of adaptor, so I think we can use most any camera. Basically, I’m debating between a Foscam camera with Blue Iris (easily compatible with Vera, right? And inexpensive). Or getting something “higher quality”. The folks at Automated Outlet insist that the Foscam cameras are junk – we wouldn’t be able to identify faces, etc. if we want to use them for security. They suggest getting for outdoor, fixed 3.6mm lens for about $75 and a dome IR camera for $68. But the recorder would be at least $425. I’m not sure how these would link with Vera, if at all. I like the idea that the Foscam cameras also have motion sensors. We have a DSC system, hooked up to Vera.
Is there a good place to read more about how cameras interface with Vera and what the tradeoffs are? In reading the threads, I’m getting bits and pieces of info, but I feel like there are some basic things that I’m not understanding…
Thanks!
i would like answers to this post as well. i just bought a vera 3 for security - didnt order cameras because i need to read more
http://docs5.mios.com/doc.php?language=1&manual=1&platform=3Pro&page=supported_cameras
should help a lot if you have a Vera 3
Thanks for the link. I have a VeraLite, so I think all that stuff is applicable.
Interesting, though, is that the Foscam POE IP cameras aren’t listed.
Not every camera that works is on that list. That list is kind of old anyway. Any ip camera that is able to expose the image url of the camera should work with vera. The pan / tilt controls is another story.
  • Garrett
Ah, thanks, Garrett.
So, I’ve narrowed it down to one of these two sets:
OPTION 1: FOSCAM + BLUE IRIS
2-Indoor:
Foscam FI8910E (White) Power Over Ethernet (POE) IP Camera $95
http://foscam.us/poe-ip-cameras/foscam-fi8910e-white-poe-ip-camera.html
3-Outdoor:
  1. Foscam FI9805E H.264 Megapixel Outdoor Power Over Ethernet (POE) IP Camera $200
    http://foscam.us/poe-ip-cameras/foscam-fi9805e-outdoor-poe-ip-camera.html
  2. Or the non-megapixel one for $109? http://foscam.us/poe-ip-cameras/foscam-fi8905e-outdoor-poe-ip-camera.html
Blue Iris: $45 http://foscam.us/blue-iris.html
OPTION 2: SECURITY CAMERAS WITH DVR
2-Indoor: Indoor dome camera with IR $70
Automated Outlet - Smart Home Automation Solutions
3-Outdoor: Eyeball dome camera $90
DVR: 8 channel DVR $520
http://www.automatedoutlet.com/Home/Video-Recording-Systems/AV-08-500
Total for Foscam with megapixel outdoor cam: $835
Total for Foscam with non-megapixel outdoor cam: $562
Total for security cameras with DVR: $930
From what I understand, I can connect the security cameras-DVR combo to my DSC alarm system and then use that to connect to Vera.
What route would you do? I would like to have high quality cameras that would allow me to identify faces well enough to be used in court if necessary – aka, no grainy photos! I wish I could see examples of the quality of video and still images these cameras take…
in my opinion (which changes the more i read this forum)
Foscam FI8910 seems to be the most compatible camera because of its plugin - if you dont have high expectations. so i would try to base everything around that. im still not convinced but i ordered a Foscam FI8910E with an IR cut outdoor enclosure http://www.ebay.com/itm/231061373349?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 ill let you know how it goes though i don’t have my hopes up on quality - the trade off being that i`m aware of many HD cameras will put a strain on the system i really dont need to take the photos to court. (that wont work in my country anyways)
Blue IRIS is also on the cards because while im convinced that its great kit to use it might not be a sensible option like a good DVR because it needs to be running 24/7 alternatively there is a plugin which uploads to dropbox http://apps.mios.com/plugin.php?id=4556 id rather not keep a DVR or PC running… wasting power
My setup initially included a Foscam 720p HD camera, and I do have to say it works, but is definitely low end compared to others. I ended up hard wiring it hoping to get better consistency, but did not improve much.
I currently run 12 Dahua (aka Q-See) along with the Foscam through Blue Iris. Blue iris is excellent and I would highly recommend it. Professional quality for a home user price.
Integration to Vera is not difficult at all. Blue iris runs its own web server that can accept commands via http. You can setup almost any of the camera plugins that accept a still picture from a camera just by pointing it to correct address on the blue iris server. Blue iris also has the ability to send commands via http to vera depending on certain triggers, so once you have everything setup it works flawlessly.
I have my setup to do things like turn on all the cameras to record any motion if the alarm is set. Or record the front door camera for 10 seconds when the door lock is opened. The best thing I liked about using blue iris is that you are relying on software that can be updated easily and customized easily for many different situations rather than relying on the very simple motion detection on the cameras themselves.
When you say low end, you’re not referring to the quality, are you? Isn’t the Foscam 720p HD much better in resolution compared to the FI8910W? Or did you mean that cameras like the latter are just better integrated with Vera? Thanks!
[quote=“nate3421, post:7, topic:177396”]My setup initially included a Foscam 720p HD camera, and I do have to say it works, but is definitely low end compared to others. I ended up hard wiring it hoping to get better consistency, but did not improve much.
I have my setup to do things like turn on all the cameras to record any motion if the alarm is set. Or record the front door camera for 10 seconds when the door lock is opened. The best thing I liked about using blue iris is that you are relying on software that can be updated easily and customized easily for many different situations rather than relying on the very simple motion detection on the cameras themselves.[/quote]
very helpful post nate - thanks !
Thanks, all!
Nate (or others) – how does Blue Iris compare to a standard DVR? I get that you have to have a computer on all the time, but anything else? I have an old ThinkPad (circa 2008 or so) that I don’t use anymore that could be repurpased for Blue Iris.
So, I could just buy cameras (doesn’t have to be Foscam, right?) and connect it to Blue Iris?
Nate - what cameras do you like? Could you identify faces well from the images?
Thanks!
Nate,
Nice work! Would you please point in the direction to find out how Vera and Blue Iris can talk to each other? I have several Foscam cameras tied to a Netbook running Blue iris. My goal is when the 4-in-1 motion sensor it connected to the Vera is armed and then tripped Blue Iris will start recording the cameras in the ?security? group. Basically looking for a remote trigger to start blue iris recording.
