Verve Lighting Control Compatibility?
Does anyone know if a Vera product can control the Verve Lighting Control system - http://www.vervelivingsystems.com/ ? This system has 10 channel controllers (mounted in a 5-6 gang wallbox) using self-powered (no batteries in the remote switches) piezoelectrically powered electronics in the remote switches with a 315 MHz EnOcean RF transceiver.
I would like to maintain the existing wall mounted switches and controllers hoping that Vera could have an interface to transmit/receive on the 315 MHz frequency using the Verve protocol.
If not, what would be the alternative to replace the 10 channel controllers and wall switches since each controller has the wiring centralized to the 5-6 gang box for each of the 10 lighting circuits.
I’ve just begun to read up on home automation and haven’t been ab;e to find reference to our existing lighting controls.
Thanks!
