V3.9 Changes:
- Several fixes for Vera UI5
- Domain name is now read from Hub Configuration reply.
V3.11 Changes:
- Added IssueSequenceCommand to start a Button Sequence.
- Added GetSequences, FindSequenceByName, FindSequenceByID commands.
- Fix for Hue RGB lights control.
- Child device attributes now set at device creation, not after and at each startup. Requires latest development branch for openLuup (2019.09.14 or later).
- Fix when saving Device Settings.
V3.14 Changes:
- Updates for Vera firmware 7.30 icon and dashboard display changes
V3.15 Changes:
- Improvement in polling routines
- Code cleanup
V3.16 Changes:
- Avoid possible busy deadlock if messages from Harmony are missed.
- Surpressing confusing log message on UpdateConfig on devices that are Hue lights.
- Added missing issue_sequence_command to http handler.
V3.17 Changes:
- Handle RemoteID change when a Hub is replaced.
V3.18 Changes:
- Fix for UI5. No longer calling luup.device_message, but back to old task message.
V4.0 Changes:
- Added Child devices for activities that can hold all command for the Activity as well as its sequences.
- Added list_activity_commands (for http handler)
- SendDeviceCommand can now handle Device and Activity child devices, and Sequences (only by Name) for Activity child devices. Required for GUI handling.
- Improved variable and log module.
- Eliminated some sleep statements.
Published as one release.
V4.2 Changes:
- Added get_automation_config (for http handler)
V4.1 Changes:
- Improved reconnect handling.
- Use of cjson if available (aprox 10x faster) than dkjson. Dropped own json version.
- Support for compact device configuration
V4.4 changes:
- Added SetSleepTimer and CancelSleepTimer commands
- Fix for openLuup if cjson package is not installed. (installation is recomended for speed)
