Version 2.3 has been sent to the App store for approval.
New feaures:
Added an Action button that will take you back to the previously visited screen. This can help navigation on screens that can be accessed from multiple other screens (through Action buttons). Use an Action button, “Previous / Next” type, and select Back as the desired action.
You can now copy the visual characteristics of a control to other controls. To use (in edit mode): double-tap the control to be copied; it will be highlighted. Then tap other controls to apply the color, style and background images of the highlighted control. To stop copying, tap the highlighted control again.
Fixed a bug: Today screen widgets not showing the right temperature unit
Fixed a bug with the Web tile. http, https should now work, self signed certs should be ok, and basic auth will work.
Fixed a bug: loading a saved screen as a subscreen now works correctly.
