Verizon, for a little while now, has had their FiOS Mobile Remote - which allows you to turn your android/iOS device into a remote for your FiOS set-top boxes.
I am assuming it does this via. a series of web commands most likely, communicating with the verizon website, which relays the command to your STB (or maybe not, possible it sends a command directly to a device on the same network via. wifi, but unlikely).
The question is, has anyone looked into seeing if this can be integrated with MiOS?
