The headline pretty much says it - where can I buy a replacement battery for VeraSecure?
I have the same question
You reminded me I need one. Last time I filed a support ticket last time and they sent me a $10 invoice. The bad news is that the replacement only lasted around 2 1/2 years… I opened a ticket just now…
Catalina Granados (Vera)
Nov 23, 2022, 17:43 UTC
Hello Eric,
Thank you for contacting us, unfortunately we no longer manufacture batteries for VeraSecure controllers.
Regards,
Catalina Granados.
Customer Care Tier 1 Support.
Since I kept my old VeraSecure battery, I tried to take it apart to see if we could easily replace the internals, and the answer is no. The battery pack wasn’t designed to be re-opened.
Thinking this might be a battery used for other applications, I tried to find a match based on the model number and specifications, but no luck.
I think we are going to have to use a UPS and give up on the internal battery.
Thanks for providing that info and doing the research. Rather frustrating. First of all (as an electrical/electronics engineer) designing it initially with a custom battery was just plain !#$%& There are plenty of available choices of standard batteries that could have served the purpose just fine. Second, I guess this just confirms again - unfortunately the company “ain’t the best” about supporting their products.
