I just purchased a vistacam 700 camera and a vistacam 1200 bell. Both of these products are available from the Vera store site and should be easy to install and configure.
However, I cannot integrate anything on my VeraPlus. I followed the instructions as described without success.
- Last step for ringer says wait 10-15 mins after wifi setup finished (???) but nothing added
- The camera image never came for the vistacam 700. So I tried the manual setup and I don’t see the camera’s MAC address on the list displayed.
- My Veraplus is connected via the Ethernet cable with automatic configuration for the Internet
- I tried to connect the cams to my 2.4Ghz wifi router (same Lan as Ethernet socket) and also directly to the mios 2.4Ghz wifi. None of this works.
Is it normal to have so many integration issues with products that should be standardized and tested on Vera controllers?
