Does anyone have experience using the Ecolink Siren / Chime with VeraPlus? According to the docs,
*Please note that the 4 tones feature require Z-Wave Multi-Channel Command class support, make sure your Hub supports Multi-Channel device class, otherwise the Ecolink sire will only operate as Siren or as Chime.
I don’t understand if the VeraPlus is a multi-channel device. I’m mostly interested in the four chimes. I’ve seen the reviews that the siren isn’t very loud, but I don’t care much about the siren.
Thanks!
