I’ve recently migrated from a Vera3 on UI5 to a Vera Plus on UI7. I notice that every time the unit reboots (or even when it’s just the Luup engine restarting), Vera attempts to reconfigure the lock. This is really incovenient since a) the process almost always fails unles the Vera is sitting close to the lock, and b) while Vera attempts the reconfig (and this takes a loooong time) all other Z-Wave commands take ages to get executed.
Is this normal behaviour for locks, or is there something about my specific lock? Also, why would the config fail unless the lock is very close? Plenty of nodes in between that should be capable of secure routing.
