I used a Vera for 5 years and somehow I’ve never heard of VeraMate. I was so excited to find it I bought the premium version without testing the free version first. I just switch to the VeraPlus controller and it doesn’t appear to be compatible. When I login to the app it just says “Errored.” and retries about 30 times before I cancel it. Is the VeraPlus supported?
Considering it looks like you are running UI7, it should have no problems… There is a known issue that is being looked into where some users experience VeraMate having trouble reconnecting to a UI7 controller, and needs to be restarted, but I’m not sure if that is your problem. Could you pop an email to support via settings/contact, and I can look into it further.
