Yes, I received some links to forums, however, I am still not there - after running luup code (sorry, I am not a programmer) I can see 3 Temperature sensors, however, I do not see temperature measurements
local masterID = 704
– master
luup.attr_set(“device_file”, “D_ComboDevice1.xml”, masterID)
luup.attr_set(“device_json”, “D_ComboDevice1.json”, masterID)
luup.attr_set(“device_type”, “urn:schemas-micasaverde-com:device:ComboDevice:1”, masterID)
luup.variable_set(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “BasicSetCapabilities”, “00=Ue1,FF=Te1,2=Ue2,1=Te2”, masterID)
luup.variable_set(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “VariablesSet”, “20-IN1 mode,1d,1,21-IN2 mode,1d,1,52-IN2 value for ON,2d,1,54-IN2 value for OFF,2d,2,67-temp change external channel,2d,3,68-temp periodical report,2d,60”, masterID)
luup.variable_set(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “AssociationSet”, “1,1.0,2.0”, masterID)
luup.variable_set(“urn:micasaverde-com:seraviceId:ZWaveDevice1”, “PollSettings”, “0”, masterID) – no polling
luup.variable_set(“urn:micasaverde-com:serviceId:HaDevice1”, “ChildrenSameRoom”, “0”, masterID) – if you want to freely move children in other rooms
luup.devices[masterID].subcategory_num = 11
luup.devices[masterID].category_num = 0
– children
for deviceNo, d in pairs(luup.devices) do
local parent = d.device_num_parent or -1
if parent == masterID then
local altid = luup.attr_get(“altid”, deviceNo)
– fix binary sensors
if altid == “e1” or altid == “e2” then
luup.attr_set(“device_file”, “D_MotionSensor1.xml”, deviceNo)
luup.attr_set(“device_json”, “D_MotionSensor1.json”, deviceNo)
luup.attr_set(“device_type”, “urn:schemas-micasaverde-com:device:MotionSensor:1”, deviceNo)
d.category_num = 4
d.subcategory_num = 8
elseif altid == “m1” or altid == “e7” or altid == “e8” or altid == “e9” or altid == “e10” then
luup.attr_set(“device_file”, “D_TemperatureSensor1.xml”, deviceNo)
luup.attr_set(“device_json”, “D_TemperatureSensor1.json”, deviceNo)
luup.attr_set(“device_type”, “urn:schemas-micasaverde-com:device:TemperatureSensor:1”, deviceNo)
d.category_num = 18
d.subcategory_num = 0
luup.attr_set("invisible", "0", deviceNo)
else
-- hide all
luup.attr_set("invisible", "1", deviceNo)
