I got the unit back from the dead, summary: started with space issues, then network and after some tweaking of the nameservers it came back from unable to do anything, then to update anything, then a constant reboot.
So I started having issues with the last firmware filling up the space and getting some errors. It was “fixed” by deleting the files suggested by support in other threads. But since saturday I was unable to do anything and have come to the conclusion that the network driver is corrupted.
I can connect to the unit from inside my network, but the unit cannot connect to anything even devices in the same network.
Here are some logs:
01 05/21/18 23:24:04.974 ZWJob_PollNode::Run job job#2 :pollnode #3 dev:141 (0xefa110) N:3 P:100 S:1 Id: 2 ZW_Send_Data to node 3 failed 1 req 0xefa000/1 abort m_iFrameID 0 <0x76d94520>
01 05/21/18 23:24:04.974 ZWJob_PollNode::Run job job#2 :pollnode #3 dev:141 (0xefa110) N:3 P:100 S:1 Id: 2 node 3, NO REPLY FROM NODE <0x76d94520>
01 05/21/18 23:24:06.684 FileUtils::ReadURL 6/resp:0 user: pass: size 1 http://apps.mios.com/get_plugin_version2.php?plugin=3166&accesspoint=XXXXX&platform=mt7621_Luup
&firmware=*1.7.3831*&oem=1 response: <0x77594520>
01 05/21/18 23:24:06.685 JobHandler_LuaUPnP::GetPluginVersionOnline iPlugin: 3166 buffer empty <0x77594520>
01 05/21/18 23:25:36.769 FileUtils::ReadURL 6/resp:0 user: pass: size 1 http://apps.mios.com/get_plugin_version2.php?plugin=6436&accesspoint=XXXXX&platform=mt7621_Luup
01 05/21/18 23:25:36.769 JobHandler_LuaUPnP::GetPluginVersionOnline iPlugin: 6436 buffer empty <0x77594520>
01 05/21/18 23:26:02.112 luup_log:16: (MyQGateway::MYQ_API::retrieveSecurityToken): Unsuccessful at connecting with the authorization URL! <0x75b94520>
01 05/21/18 23:26:03.332 luup_log:144: OnkyoReceiver: Running Network Attached I_OnkyoReceiver1.xml on 192.XXX.XXX.XXX <0x77594520>
01 05/21/18 23:26:03.333 IOPort::Connect connect -1 192.XXX.XXX.XXX:60128 <0x71af7520>
01 05/21/18 23:26:07.355 IOPort::Connect connect -1 192.XXX.XXX.XXX:60128 <0x71af7520>
01 05/21/18 23:26:11.359 IOPort::Connect connect -1 192.XXX.XXX.XXX:60128 <0x71af7520>
50 05/21/18 23:26:15.451 luup_log:144: OnkyoReceiver: debug: ISCP request: !1PWRQSTN <0x77594520>
50 05/21/18 23:26:15.452 luup_log:144: OnkyoReceiver: debug: ISCP request returned in 0ms <0x77594520>
50 05/21/18 23:26:15.453 luup_log:144: OnkyoReceiver: debug: ISCP request: !1MVLQSTN <0x77594520>
50 05/21/18 23:26:15.453 luup_log:144: OnkyoReceiver: debug: ISCP request returned in 0ms <0x77594520>
50 05/21/18 23:26:15.454 luup_log:144: OnkyoReceiver: debug: ISCP request: !1SLIQSTN <0x77594520>
50 05/21/18 23:26:15.454 luup_log:144: OnkyoReceiver: debug: ISCP request returned in 0ms <0x77594520>
01 05/21/18 23:26:15.454 LuaInterface::CallFunction_Startup device 144 function receiverStartup took 12 seconds <0x77594520>
01 05/21/18 23:27:19.434 JobHandler_LuaUPnP::ConfirmUpnpFile can't retrieve http://192.XXX.XXX.XXX:8008//ssdp/notfound basefile notfound <0x72ef7520>
It starts not updating the time nor getting the location, so I checked the nameserver configuration and found this:
root@###:/etc# cat resolv.conf
search lan
nameserver 127.0.0.1
then I modified to add the google servers and restarted network, and now I get this on the net troubleshooting:
=== IP Configuration ===
br-wan Link encap:Ethernet HWaddr B4:XX:XX:XX:XX:XX
inet addr:192.XXX.XXX.XXX Bcast:192.XXX.XXX.XXX Mask:255.255.255.0
eth0 Link encap:Ethernet HWaddr B4:XX:XX:XX:XX:XX
eth0.1 Link encap:Ethernet HWaddr B4:XX:XX:XX:XX:XX
eth0.2 Link encap:Ethernet HWaddr B4:XX:XX:XX:XX:XX
inet addr:127.0.0.1 Mask:255.0.0.0
ra0 Link encap:Ethernet HWaddr B4:XX:XX:XX:XX:XX
rai0 Link encap:Ethernet HWaddr B4:XX:XX:XX:XX:XX
External IP:
=== Testing Gateway: 192.XXX.XXX.1 ===
GATEWAY:OK
=== Testing DnsServer: 192.XXX.XXX.1 ===
DNSSERVER1:OK
=== Testing External Servers ===
GOOGLE.COM:FAIL
STA server: FAILED
EVT server: FAILED
TS server tunnel connection: FAILED
FWD server: FAILED
FWD server tunnel connection: FAILED
SSH_TUNNELS:NONE
== DONE ==
After that it was able to send out some notifications, but then started rebooting itself and reverting my changes. While I was trying to set the nameservers back, I started getting Segmentation Faults while connected thru SSH. In each restart I tried to update the nameservers and to check the “troubleshoot network” results. Well, at some point something worked and now I’m able to work with the unit. It connected to the servers and finally is stable enough to be used. Network test is:
[code]=== IP Configuration ===
inet addr:192.XXX.XXX.1 Bcast:192.XXX.XXX.XXX Mask:255.255.255.0
External IP: XXX.XXX.XXX.XXX
GATEWAY:OK
DNSSERVER1:OK
GOOGLE.COM:OK
STA server: OK
EVT server: OK
TS server tunnel connection: OK
FWD server: OK
FWD server tunnel connection: OK
=== SSH_TUNNELS: ===
Found 1 ssh sessions running
Remote Control Tunnels are running
== DONE ==
[/code]
So, long story short, the culprit seemed to be the unit unable to connect to the servers.
I hope it stays stable enought until I move out of it to openLuup in a raspberry pi.
