I have a problem. Ever since the VeraMobile update v.3.36 (3) was released, I can’t view the streaming from my cameras. It goes to the camera view, but has a big Connecting with a constantly turning circle. I have 3 iOS devices, and on 2 of them, I had an older version of the VeraMobile app, and they were working just fine:
Apple iPhone 11, iOS v.13.3.1. This is my cell phone, VeraMobile app version 3.36 (3)
Apple iPhone 6S, iOS v.13.3.1, back up old phone, no SIM card, just WiFi and Bluetooth; VeraMobile app version 3.34 (8)
Apple iPad 5th generation, iOS 13.3.1, Vera app version 3.35 (12)
Then, the iPhone 6S did an automatic update to the VeraMobile App to the most current version, and that, too, went into the spinning Connecting mode.
I contacted Vera tech support, and they wanted to remote into my devices in admin mode, but I don’t feel that this is a device issue, since I was able to see that previous versions of the app releases worked fine. I did tech support for a software company, and usually was the one to take a lot of the calls after a buggy release of our software, and pass it on to our programming department to address. This issue seems exactly like a buggy version release.
Has anyone else had this issue, and if so, were you able to fix it?
I’m not sure if it is allowed, but if anyone else has had this problem, is it possible to PM me so I can get on it and fix it; or, at least know that Vera tech support/management is addressing this issue, PLEASE?
Thank you for getting back to me! It is greatly appreciated!!!
I have an indoor camera, which is the VistaCam 700, and I have an outdoor camera, a VistaCam (VeraCam?) 1101, both of which were purchased through Vera.
FYI, I also have enabled Remote Access through the Vera app, in the case you need to remote in and see.
Hello,
I received your message.
We started to investigate what can cause your camera issues.
If is ok with you I will contact you in private for more details as we go forward.
Thank you
I have a similar issue. My camera show a play link then say Failed to receive image from camera after clicking it. The cameras stream properly from the web page, this issue only exists in vera mobile. This is a vera plus with cameras provided by the blueiris plugin.
I have a similar issue. I use Foscam cameras with a snapshot.cgi. I have the same problems like described by @Juppers
On 7th march 2020 I informed Vera technical support and Leonardo S. (and I hope he is not alone) is still working on it.
Everyone-
Here’s an update to the issue with the VeraMobile App Version 3.36 (3) streaming stuck on connecting, iOS 13.3.1:
I worked with tech support and got a reply as well from the iOS development team. Everyone was very helpful and concerned about this. I was finally given a link to join the iOS BETA testing, and reverted back to a previous build (think it was 3.36), and everything worked. The iOS development team then gave me info that they had been in contact with tech support, and informed me that tech support had found that there was an issue with either my login or my passwords for my cameras.
I went ahead and changed the passwords for my cameras, both on the URL control for the cameras, and also within the Vera app. I had been utilizing the newer universally accepted password entry protocol, which, when entering a password, requires use of UPPER CASE and lower case letters, numbers, and symbols.
Doing this, and entering following those guidelines, everything had worked up to version 3.36, but then stopped working. Upgrading to the latest BETA did not resolve either.
Once the passwords were changed eliminating a symbol that I had used, everything went back to functioning properly. This also allowed me to view my cameras in a web browser on my main computer, which had never worked properly. I’d had that problem basically from day one (about a year ago, once I had switched from Lowe’s Iris to Vera), and had just blown it off. Even at that time, tech support was wondering why I could not view my cameras in Internet Explorer, Microsoft Edge, Firefox, nor Google Chrome. I still have to click the Use Adobe Flash Player to view the cameras, but it is working.
Everything is back up again, thanks to tech support and the iOS development team, and I want to say thanks to everyone! Appreciate the assistance and guidance!
