is it possible for Veramate to display temperature reading from Ecolink/Monoprice motion sensor? I could do it with Homewave but Veramate.
I haven’t encountered that device before. Please send diagnostics to support (via the in-app contact), and I’ll add it to the development list.
Yes, well, some motion sensors with Temp sensing can be.
From what I have seen, the Ecolink motion sensor I have does not have the Thermal sensor, at least not by default like the monoprice and GoControl.
Using the “Add a temperature” app in Vera, you can easily add the temperature signal from the motion sensor with include it (my GoControl does) in Vera which shows up as a discrete device in veramate, just like any other switch or device.
Here’s a link back to the thread where this was originally discussed
