[ul][li]Apple Watch upgrade stability fixes.[/li]
[li]Apple Watch upgrade to work with iOS8.2.[/li]
[li]Miscellaneous UI enhancements.[/li]
[li]Better support for UI7 changes with thermostats.[/li]
[li]Support for GCAL3.[/li]
[li]Confirm showing password on login for multiple failures.[/li]
[li]Support for Vera username case sensitivity bug in UI7.[/li]
[li]Fix inability to disable voice control “speak reply”.[/li][/ul]
Now with better control. Design your Apple Watch layout via the new settings/Apple Watch Layout area.
Homepage UI:
VeraMate has gone through a complete rewrite of the UI layout. You now have a lot more control on the VeraMate homepage (not device view).
[ul][li]Sort and move buttons in any order.[/li]
[li]Add new home page screens - flip left and right for more displays.[/li]
[li]Add new sections.[/li]
[li]Control button sizes per section.[/li][/ul]
Miscellaneous:
Additionally, multiple enhancements have been made, including:
[ul][li]Apple Watch performance fixes.[/li]
[li]Configuration backup now stores user background images.[/li]
[li]Some buttons now attempt to show images via json configuration.[/li][/ul]
Version 9.3 (Released 22nd July, 2015)
[ul][li]PresetModes fix - certain situations still exist where the synchronization failed.[/li]
[li]Alerts button now have configuration to show “always”, not just when alerts are found.[/li]
[li]iPad now also supports reordering on left detail screen.[/li]
[li]New configuration options in settings, for backgrounds. Change opacity and black/white fades to better show against buttons.[/li]
[li]Recent UI7 firmware change for “multi state button” is now supported.[/li]
[li]Better handling some situations when downgrading from UI7 back to UI5.[/li]
[li]Clearing of temporary files which have taken up disk space.[/li][/ul]
Version 9.4 (Released 7th Aug, 2015)
[ul][li]NEW: show web cams on main screens.[/li]
[li]Further performance checks for Apple Watch, to minimise traffic required to show data.[/li]
[li]Ability to use more generic IP web cams by entering the full URL which will retrieve a snap shot.[/li]
[li]Attempt to support more thermostats.[/li]
[li]Configuration option to turn off button animations due to a framework issue affecting some users.[/li]
[li]Web cam PTZ buttons now more responsive.[/li][/ul]
Known Issues: Unfortunately some webcams have lost their PTZ buttons, and some manufacturers thermostats don’t appear to have been detected correctly. A fix will be put out asap for these.
Version 9.5 (Released 19th Aug, 2015)
[ul][li]Fixes for webcams PTZ and some manufacturers thermostats. [/li]
[li]Fix push notifications for new users.[/li]
[li]Webcam can be viewed on Apple Watch.[/li][/ul]
Version 9.6 (Released 12th Sep, 2015) (Slight delay to update, sorry )
Introducing multiple new language translations ! Swedish, Russian, Dutch, German, Spanish, Japanese, Chinese (simplified).
[ul][li]NEW: Allow new setting for controlling home page buttons via a popup - new ability to control dimmable controls via homepage[/li]
[li]Fix preset mode activation using GeoFencing[/li]
[li]Support for more thermostats / fix issues[/li]
[li]Bug removing today widget items[/li]
[li]Miscellaneous bug and stability fixes[/li][/ul]
[ul][li]Initial support for French language.[/li]
[li]BUG: Fix voice control for upgrade issue.[/li]
[li]BUG: Login validation against correct vera if one exists locally.[/li]
[li]Support for more thermostat plugins.[/li]
[li]Miscellaneous bug and stability fixes.[/li][/ul]
[ul][li]Fix google drive connection.[/li]
[li]Better voice control handling.[/li]
[li]Add thermostat buttons to home page.[/li]
[li]Webcam button shows view on main iPad screen.[/li]
[li]Show wattage as integer to fit on screen.[/li]
[li]Show working indicator on Apple Watch.[/li]
Version 10.0 (Released Nov, 2015) (Delayed notification - not sure why this didn’t save properly )
Large UI update with a lot of underlying UI changes. Multiple button styles, custom lists (allowing, for example, to create a list of certain lights, which only show when any are activated), and more.
There have been some micasaverde server and/or firmware issues over the last 2/3 weeks which have caused issues for VeraMate connecting. 10.1 attempts to detect and better handle these issues on external servers, which may have caused some internal connection information to be lost.
A diagnostic screen (settings/diagnostic) is now also available to show server errors, and connection attempts.
Miscellaneous bugfixes:
[ul][li]Fix support for iOS9 and push notifications[/li]
[li]BUG: Voice activation for scenes.[/li]
[li]Better handling switching between multiple vera servers.[/li][/ul]
If you are on UI7, please make sure you on the latest firmware as this has helped rectify some connection issues
[ul][li]Fix backwards compatibility issue with GeoFences and pre iOS9.[/li]
[li]Fix issue with popup control not working for sensors.[/li][/ul]
We’ve had an extended December off due to onforseen circumstances, but are back, and going through a huge backlog of queries and requests. Hope you all had lovely holidays.
[ul][li]Fix image and buttons not working for alarm panel on homepage.[/li]
[li]Fix an issue where the preset mode is not selected correctly.[/li][/ul]
GeoFencing has been rewritten to support better reliability and lower signal areas - this should increase reliability significantly. Please note, use of GPS will use more battery - future releases are investigating minimizing this.
[ul][li]UI enhancements for a cleaner interface.[/li]
[li]Handle certain Micasaverde server problems, and switch to backup server (UI5).[/li]
[li]Memory enhancements.[/li]
[li]Miscellaneous stability fixes.[/li]
[li]More diagnostic information for geofencing.[/li][/ul]
Version 10.6 (Released 17th Feb, 2016)
[ul][li]Fix issues with voice control.[/li]
[li]Better image handling for devices.[/li]
[li]Support more thermostats which were having problems showing correct setpoints and/or fan mode.[/li]
[li]Ability to override the metric value for a thermostat.[/li]
[li]Better VirtualClock plugin support, to have configurability for triggering scenes based on a time.[/li]
[li]Preset mode to poll for state change.[/li]
[li]Ability to now configure a background colour for a selected preset mode (via settings/themes).[/li]
[li]Minor UI issues.[/li][/ul]
Version 10.7 (Released 23th Feb, 2016)
[ul][li]Support for more thermostats.[/li]
[li]All thermostats with heat/cool ability should be detected properly and be able to control each setpoint individually.[/li]
[li]Ability to swipe left/right through room lists.[/li]
[li]All generic devices can be added to the homepage.[/li]
[li]UI enhancements for generic device view.[/li]
[li]Stop sound detection pausing music on startup.[/li]
[li]Miscellaneous bug and ui fixes.[/li][/ul]
[ul][li]Device rows and tiles will now show the state change background colour (pending/running/error).[/li]
[li]Fix issue with Apple Watch controlling normal on/off devices[/li][/ul]
Version 10.9 (Released 27th April, 2016)
[ul][li]Better support for nest connect on UI7[/li]
[li]Alert configuration options: ability to disable badge, and set the maxium history to retain[/li]
[li]Miscellaneous stability fixes[/li][/ul]
