Does anyone know if VeraMate and imperihome apps work with ALTUI. Should I switch my vera edge to ALTUI?
They will work fine with or without altui.
Thank you…do you recommend altui?
ALTUI doesn’t replace your existing UI, it is a secondary UI you can use. The original UI is unchanged. Go ahead and try it and see if you like it. If you don’t, it only takes a few seconds to remove the plugin.
oh ok i didnt know that from reading it seems that it was a replacement…Thanks!
