I tried to find a way to include the 4 devices created by the fibaro motion detector device in Veramate but I only see the ‘motion sensor’ in the device list in Veramate.
Are the light and temperature devices supported by Veramate ?
VeraMate only loads configuration directly from your Vera box, so if Vera doesn’t display the other 3, you wouldn’t see it in VeraMate. Could you confirm whether you can see the other 3 devices in the Vera web UI itself?
If you can, could it be they are showing under a room you’re not expecting (such as, “no room”) ? If not, please send the diagnostic in-app via settings/contact page.
