I have the laster FW. This unit is the master with 3 slave units, so it sees its own z-wave devices as well at the devices of the slave units. I am creating all scenes on this master unit. When I make any change that requires a save, the save gets lost after the unit reboots. This is a huge annoyance. I contacted support and they suggested I restore from backups. I restored several backups, with each try using an older backup file, and finally found one that would hold changes. Well…after a few days it started again. Has anyone else had this problem? Does anyone have a good suggestion as how o proceed?
There are several discussions recently about this. You need to provide more details. How many devices, plugins, what plugins are installed.
If you ssh into your Vera, what does the commands df and free show? If you are not sure how to do that, I advise you search the forum.
- Garrett
